Sebring 04 V6 Stall problem
Hi ,
two questions only this time :-)
-Got rough idle, sebring 04, around 500rpm and sometimes engine V6, 2.7L stalls.
Nothing on scanning tool and no MIL illumination.
- is it possible to use 10W40 oil on my engine?
Anybody could guess as to the cause of your rough idle, worn plugs, vacuum leak, clogged injectors, fuel filter, head gasket leak, bent valves, who knows? Check/fix cheapest things first.
As to oil, it's "possible" to use Crisco, that doesn't make it a good idea. Best bet is to stick to the manufacturer's recommendation.
ManuteSwol
04-25-2011 06:12 PM
