sebring 08 not shifting out of park
Eariler today i left and went out came back home with no problem, a few hours later i get ready to leave again. When i go out i start my car and push the brake to shift out of park to go into reverse, but it wont shift out of park to allow me to go in reverse, drive, or even neutral. Not for sure what happened.
nope tried that and it didnt work i can hear the sound of when i push the brake in gear shifter but nothing happens even tried the manual override under the cup holder to bypass to see if that worked but no go on that one either
Similar thing happened to my g/f's car several years ago. Perhaps the solution is the same.
In her car, pushing down the brake caused a worm-gear in the shifter to move the safety catch. The safety catch itself became stuck, and the plastic worm gear broke trying to move it. We wound up getting rid of the safety catch.
Were you able to move anything under (or in) the shifter when you did the manual override?
08 Sebring shifter part broken, won't shift out of park
When my 08 Sebring convertible didn't shift from park it happened suddenly and without warning. When I had it towed to the dealer they said a shifter part had broken and they replaced the shifter. Thankfully it was under warranty.
Shift out of park fix
i dont take credit for this. Thanks to TBoneMM and Fwlrichard. i found this on wiki answers and it works great. i thought i would share with you all. ill paste the text and the link.
The gear shift in the automatic transmissions have a spring that allows you to take the vehicle out of park that is connected to a pink piece next to the shifter on the drivers/left side. The pink piece is prone to failure and breaks thus releasing the spring.
The correct fix to this is buying the $127 transmission shifter assembly. There are methods to allow you to drive it to the dealership. One way is to remove the chrome bezel around the shifter, on the center console, and use a screwdriver to pull the pink piece located on the left of the shifter towards the back of the vehicle after applying sufficient pressure to the brake pedal. This will allow you to make it to the dealership to buy the part to fix it or allow them to install it for you.
Or
Sense you now know whats wrong with it you can quickly repair this your self and save the $127. Pop out the A/C control panel it has 3 plugs on the back of it and 1 plug for the middle console, next remove the 2 10mm screws located near the top where the A/C panel was and the 4 in the middle console. Pull up on the emergency break hard so that it is all the way out of the way. At last lift up on the middle console and it comes right out. The FIX is simple and better then the factory replacement part, drilling a small hole through the pink plastic about 2 10ths of an inch away from the right side. Reattach the spring to the new hole and the black tab on the right back side it's about 2 inches from the pink plastic. Then reinstall everything. Hope this helps, and saves you some money.
LINK
http://wiki.answers.com/Q/Why_can't_...rysler_sebring
also on instructables with pictures
http://www.instructables.com/id/2008...nsmission-fix/
Or
LINK
01goldsebring
11-14-2009 11:05 PM
