Sebring - choke stays on too long.
Hi,
I have a Sebring 2001 Coupe with 172000 KM. The engine light is on (don't know the code...too cheap to get it tested). I find the choke stays on too long when the car is cold. It revs approx. at 1200-1300 RPM for about 5 minutes. Is this normal? Cuz when it's reving that high it's hard to stop at the stop signs...so I shift into neutral to save on brakes. I know some will say to just get the engine light code...but before I do that I was wondering if anyone had a clue as to what would be causing this issue? Or maybe it's normal and I should just let my car idle a little longer before I take off. Thanks to anyone who can help.
RE: Sebring - choke stays on too long.
Pls post your fix regardlessif it's a “you done it repair”or if you took it to the shop.
Onething is to listenfor vacuum leaks, openthe hood and listen for hissing noises; I had had av-6Chrysler with a 2.5Mitsubishi engine with the exact same issue. Once I tookcare of the vacuum leak it idled properly plus the check engine light went away as well.
Being cheap is costing you money, and if you borrow the car to someone they can have a problem with it and not be able to handle the shift in neutral trcik and not be able to sop in time.
There are several auto parts stores that will do a code check either free or for like Five bucks. Get "R” done. They will also hopefully give you a print out of whatMIGHT BE the possible PROBLEM(s). Codes are not a positive answer however, but usually they give you a good clue where to look for the problem.
the auto parts stores want you to use their reader service CUZ they know you very likley will purchase parts to correct your issue...and likely you like others Don't want to spend money in labor to pay a shop to properly diagnose it,, (that’s assuming they are good, trained and trustworthy, reputable) so you likley will throw parts at it in hopes to save money and sometimesafter one item you may be better off taking it in to have it repaired.
If you are in a cold state winter is coming and slippery roads that will give you problems.
It's also wasting money on gas so it's costing you money, just a little more ever time you drive.
The one I got has a "Toptak" brand name. It's made in China so it might be sold under other brand names too. It comes with a book of codes, both generic and those specific to certain manufacturers.
In the absence of any more information such as codes from the computer, one could guess that the computer is not sensing that the car is warming up. By the way, they don't have a choke these days. Chokes went out when carburetors went out. Anyway, It might be a problem with the coolant temperature sensor, or intake air temperature sensor, or maybe the mass air flow sensor, or maybe the throttle position sensor. Or maybe your throttle body needs a good cleaning. Or maybe the computer has gone bad let's hope not. Only real way to find out if it's one of these is to grab the codes. Good luck. Keep us posted.
kernst52
02-13-2012 02:34 PM
Endeka
07-25-2011 10:24 AM
sebringphanatic
07-25-2009 01:03 AM
