Sebring will not start everytime
Old 05-23-2007 | 01:13 PM
blgrass's Avatar
Default Sebring will not start everytime
1998 Sebring LXI will not start everytime.Sometimes it will start the first time and then sometimes it takes 5 times to get it to start. Replaced the distributor and it started everytime for a week and the it started back doing the same thing in the begining. Had it checked with a computer and no fault was found. Replace the CPS and nothing changed. HEEEEEEEEEEEElp
Old 05-24-2007 | 01:45 AM
Default RE: Sebring will not start everytime
year and engine
Old 05-26-2007 | 06:48 PM
blgrass's Avatar
1998 chrysler sebring v6
Old 05-27-2007 | 01:05 AM
there is a tsb for a computer update for long crank time cold start need your vin to see if it applys to your build date.
Old 05-27-2007 | 06:43 PM
blgrass's Avatar
I'm at work right now and will send it to you tomorrow. Thanks
Old 05-28-2007 | 11:56 AM
blgrass's Avatar
Okay,this is the vin #4c3au52n1we103537
Old 05-28-2007 | 12:11 PM
NO: 18-10-99 SUBJECT: Start And Stall Or Slow Rough Idle Immediately After Start-Up In Cold Ambient Temperatures/Leak Detection Pump (LDP) Monitor Run Test Capability. DATE: May 28, 1999 OVERVIEW: This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software (calibration changes). NOTE: THIS INFORMATION APPLIES TO VEHICLES WITH A 2.5L ENGINE. SYMPTOM/CONDITION: Some vehicles may exhibit start and stall or slow rough idle immediately after start-up in ambient temperatures of -18o to 10o C (0o to 50o F). Additionally, this calibration reinstates the LDP Monitor Run test for vehicles equipped with this system.
Old 05-29-2007 | 01:44 PM
blgrass's Avatar
So you are saying that mine is not under this bullett? and if not what is going on?
Old 05-29-2007 | 05:13 PM
no that is a tsb they does apply to your car but u are way out of warranty and would haft to pay for a computer update. Does the tsb sound like what your car is doing if so then this may fix your car.
Old 05-29-2007 | 05:34 PM
blgrass's Avatar
No.after reading again.Mines just starts when it wants to.Sometimes it takes 5 turnovers to get it to start and other times just one.Have installed 3 different rebuilt distr. and only one of them last a week. Was told by a chrysler mech that only the oem ones would only work. So that is where i am with a rebuilt distrb. and it just started 3 times in a row ,but the distrb was installed Sunday and only started 1 time then
