serpentine belt on 2000 sebring
Old 09-20-2009 | 05:21 PM
jimratz's Avatar
Default serpentine belt on 2000 sebring
how do I change a serpentine belt on 2000 sebring
Old 09-21-2009 | 04:10 PM
Jack up the car, put it on a solid jackstand and remove the right front wheel. Remove the splash shield (inner fender) by pulling out the push-in fasteners. Now you have access to the belts. Depending on your engine, there are different tensioners, but you should be able to figure it out by looking at it. Relieve the tension and slip off the belt. As long as you are in there, you might as well replace the belt for the power steering pump at the same time.
Old 09-25-2009 | 12:56 PM
htran2313's Avatar
Default belt removal
How do i take the Power steering belt off a 2000 Sebring.
i see that the serpetine belt has a tensioner but not the power steering belt. what are the steps to remove the belt. i'm not seeing any bolts to loosen to remove the belt. thanks
yelram
07-15-2014 07:49 AM
fakeplay
11-16-2011 10:51 AM
Baronesa
08-23-2011 12:09 AM
robbiedog
09-04-2007 05:19 PM
donandsandra
07-07-2007 05:17 PM
