squeeling sound!!! NEW?
i just got my timing belt,tension pully, idler pully, water pump, cam shaft seal, air cond belt, alternator belt replaced on my 1998 sebring coupe lxi.... when i turn it on it squeels real loud for a couple of seconds around 45 se or more then if i turn on my air (heat) it squeels even more... what the hell can this be, i think either two things: belts to tight or loose OR the belts needs to set in?
RE: squeeling sound!!! NEW?
alrite thanks called the guy that did it, hopefully he doesnt try to screw around... any one know if they make a universal weatherstrip to go around a sunroof.... my sunroof rattles alot i tightened all the torex bolts that i could see on the sunroof so my guess is the weatherstrip
it doesn't leak at all, but it rattles crazy very annoying, and when i slam the door close the window will pop up, but i thought maybe something was loose but i tighten the 2 torex on each side of the sunroof and the frame...
sirlawrence1
06-22-2008 01:13 PM
11-23-2005 01:31 AM
cajundaddy
11-20-2005 09:50 PM
