Temperature controls not working
Old 05-02-2011 | 10:24 PM
timpvjr's Avatar
Default Temperature controls not working
Hey, I have an interesting problem I was hoping someone here could help me with. If the fan is blowing hot air, and I turn the **** to cold, it will still blow hot. The only way to make it blow cold is to turn the other **** to defrost and back to whatever setting. Then it's stuck on cold. In order to make it blow hot again, I have to turn it back to defrost and back.
Old 06-13-2011 | 04:30 AM
02sebring's Avatar
I have the same exact problem! I posted about it and one person's reply was the wires are no longer soldered together correctly. Just pop the dash off and you can look behind the ***** at the white connector. I hope this helps I still haven't looked at mine yet.
Old 06-13-2011 | 10:17 AM
alexanderc's Avatar
This could also possibly be a bad Blower Motor Resistor. Check that as well.
Old 06-13-2011 | 05:07 PM
Djinn-n-Tonic's Avatar
I would love to hear that Explanation.....
Anyway......You have a classic case of Broken Door Syndrome. The Pivot Develops a crack, and the motor "Over travels"...The only way to bring it back is to reverse direction.....
Technically, It really has Nothing to do with HOT/COLD....but rather the Overlap of the mode doors...Typically, Atleast from the ones Ive seen...its the defroster door that causes all the issues.
Now the bad news, Remove the dash , remove the heater box, dissassemble it, and find your broken door.
No other way around it.
darkcild101
05-20-2015 02:03 PM
auto_geo
07-04-2010 06:04 PM
mikesaiztx
12-10-2009 11:07 PM
rastoma
07-07-2009 08:41 PM
pghmark14
04-29-2009 05:21 AM
