trans problem!!!!
Old 11-16-2011 | 12:54 PM
Motor_man's Avatar
Default trans problem!!!!
Hey guys have a trans problem on a 2001 chrysler sebring 2.7 eng trans will not shift out of low 1 (have to pull over turn car off restart sometimes trans will shift after that have a 0700 code &0605 code any advice would be helpfull!!!!! trans does not slip,trans fliud full,was thinking it could be trans control module THANK,s JAMES EAGAN
Old 11-16-2011 | 06:38 PM
605 is internal trans controller
Old 11-19-2011 | 12:40 PM
LeoM's Avatar
My 99 did the same thing and all it needed was to replace the vehicle speed sensor.
Old 11-23-2011 | 03:46 PM
Motor_man's Avatar
Thank's for the info i'll check the speed sensor
Old 11-23-2011 | 06:39 PM
I might as well give up this gig its like talking to brick walls here most of the time. Do i not have any pull around here being a Chrysler tech for 15 years?
Symptom:
P0605-INTERNAL TCM
POSSIBLE CAUSES
TCM - INTERNAL ERROR
TEST ACTION APPLICABILITY
1 If there are no possible causes remaining, view repair. All
Repair
Replace the TCM. WITH THE DRBIIIt PERFORM QUICK
LEARN AND REPROGRAM PINION FACTOR.
Perform 41TE TRANSMISSION VERIFICATION TEST - VER 1.
Old 11-23-2011 | 07:40 PM
TNtech's Avatar
I know right? LOLz
Old 11-25-2011 | 01:59 PM
Motor_man's Avatar
Default Another brick in the wall
Originally Posted by TNtech
I know right? LOLz
Thank's for the great info/ you have been a big help!!!!HAVE A GOOD ONE!!!
parlayjay
04-18-2010 04:28 AM
sosomechanic
11-25-2008 09:36 AM
continental777
03-14-2008 04:47 PM
shibasmom
01-30-2008 11:44 PM
erik
12-13-2006 11:37 PM
