Transmission Noise?
RE: Transmission Noise?
no doesnt sound like a clunk. When I start the car and go from park to reverse sounds like a door creaking. It transfers smooth and everything just sounds weird, but I'm guessing by the research i've had that this is normal im not sure
it's the solenoid that moves that particular gear I would bet... not much you can do about it... make sure the fluid lines are solid and full... could be an air bubble in the line.. totally common... I wouldn't worry about it... just dont go in reverse with your girlfriend in the car... bad bad bad...
bgeise
11-05-2014 04:38 PM
MOHAMMEDHU2003
07-22-2005 05:51 AM
