washer fluid pump issue
Old 02-18-2013 | 06:28 PM
sdeal5's Avatar
Default washer fluid pump issue
I just bought a 1999 Sebring lxi.. I noticed that there was no washer fluid under the hood so today I filled it up.. but it won't pump.. I can hear the pump running but no spray... Has anyone ever had this problem, and if so how did u fix it????
Old 02-19-2013 | 11:33 AM
If the pump runs, there must be either a blockage or leak somewhere. Start at the pump and check the entire length of the hoses to see where the flow is stopped or diverted. This isn't rocket science, it just takes persistence. You can do it unless you'd prefer to pay a pro $90 an hour to do the same things.
Old 02-19-2013 | 02:25 PM
sdeal5's Avatar
Dats just what I thought... I think something must of plugged up the line... And no I'm nt gonna pay anyone to fix it for me... I'm a diy kind of guy... Thanks for confirming what I was thinking.. wish me luck..
Old 04-14-2013 | 06:38 PM
sdeal5's Avatar
Question
So I finally got a chance yesterday to trouble shoot my windshield washer fluid... Finally got it to spray again... But now it only sprays out of the driver side nozzle... Only out of the hole to the left.. and it doesn't even hit my windshield.. instead it just shoots over the car... Would replacing the nozzles fix my issues??? What do u guys think???
Old 04-14-2013 | 09:00 PM
Probably. Unless there's a blockage in the tubing going to the right nozzle.
The parts won't set you back much so it's worth a try. Come back again and let everybody know how it went.
The alternative is to stick a pin or needle in the nozzle and see if you can clear it out. Even if you wreck the nozzle that way, you're no worse off.
Old 04-14-2013 | 11:37 PM
sdeal5's Avatar
Cool
You know I was thinking about doing just that.. using a pin tr try and clear it... I found what appeared to be caked up washer fluid in the t where the 3 lines connect... There was also a a lil round peace of metal in the bottom side of the t where the line connects to the pump... Is it suppost to be like that??? .. As for the nozzle replacement kit... Auto zone has them for about 17 bucks... Wish me luck... And yes I will post my end results mos def... Thanks again
Old 04-15-2013 | 09:06 AM
Not sure what you mean by the little round piece of metal, but if it looks like it doesn't belong there, it probably doesn't. Like I said before, this ain't rocket science. It's a very simple and straightforward system there.
Old 04-20-2013 | 04:34 PM
sdeal5's Avatar
Thumbs up
Well I'm back to let u guys know what I did and hoe it all went. Today I went to auto zone and got a new pair of nozzles and a vacuum t and now it works perfectly now... Thank u for all Ur help on this fix*
shaunneff
07-07-2011 11:58 PM
sonician
10-28-2010 05:35 AM
epd
03-02-2008 10:42 PM
jasons4
12-24-2007 11:40 PM
quattj
04-02-2007 04:29 AM
