What do these check engine codes mean???
Old 09-06-2008 | 11:34 AM
canislupus7777's Avatar
Default What do these check engine codes mean???
I have a 2004 Chrysler Sebring. For the last 2 weeks my engine light has beenlighting upon and off. When the light comes on the car starts acting up like it's going to cut off while I'm driving. It happens intermidatedly. When I plugged it in to read the codes I got: 340, 100, 12. I've been told one code means a problem with Camshaft Position Sensor. Does anyone know what the other 2 codes are? And can you give an estimate on how much it's going to cost to have it fixed?
Old 09-07-2008 | 01:38 AM
Default RE: What do these check engine codes mean???
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
what engine size do u have
cost will be based of who u use parts they use and if they know what they are doing.
Old 09-08-2008 | 10:01 AM
P0012 = "A" Camshaft Position - Timing Over-Retarded (Bank 1)
P0100 = Mass or Volume Air Flow Circuit Malfunction
Since it's an intermittent problem, it's more likely a bad wire or connection rather than a bad sensor or broken part. That makes it even harder to track down. Carefullylook at the wiring and connections, you might see a burned/melted or frayed wire or loose connector.
josh24200
02-24-2021 09:17 AM
Jfizzle
02-22-2020 05:37 PM
valkyr
09-19-2009 11:41 AM
blarf
09-04-2006 08:21 AM
