What fuse controls the cigarette lighter on a 2006 Sebring Touring?
Old 12-30-2008 | 11:43 AM
tkbelisle's Avatar
Default What fuse controls the cigarette lighter on a 2006 Sebring Touring?
Cigarette lighter won't work.
Old 12-30-2008 | 03:32 PM
Default RE: What fuse controls the cigarette lighter on a 2006 Sebring Touring?
blue 20 amp under the hood
Old 04-29-2011 | 08:13 PM
starzz's Avatar
Thumbs up
Had the same problem on my '01. Diagnosed fuse to be blown. Bought a 20 amp 32 Vdc Cooper Bossman fuse from AutoZone for about $4.50. Replaced. Checked outlet. Working fine. Done.
Old 04-29-2011 | 08:30 PM
Djinn-n-Tonic's Avatar
Dude....Im not trying to be an ****....But 4.50 for a Fuse?????
FRED'S fuses work just as well, and if you have a bucket...the local Junkyard throws them away......If not and the guy wants to be a Jack-***....flip a Quarter at him for as many as you can fit in your pocket....
A 20A fuse is a 20 A fuse.....There is NOTHING special about two different bands, or different metals or designs.....If the circuit overloads, it breaks current flow.....Thats all it was intended to do...... And it must be done,,,,If you develop an overload, you WANT the fuse to pop, and protect your car from burning to the ground....Not sit there and look pretty "WAITING TO POP"... ALL Blown Fuses are the same....Blown...ANd the Melted ones are even closer...Plastic Globs.
Old 04-29-2011 | 10:09 PM
starzz's Avatar
I'm with ya, this is overpriced... but several places I went to, incl. my shop that confirmed the fuse went, didn't even have this fuse... so instead of wasting gas going all over... Hopefully, this one last and there is not a fundamental electrical problem.
Old 07-24-2011 | 10:08 AM
JCM_temp's Avatar
Default Which fuse is it?
Starzz,
can you tell me which fuse it is? Neither fuse panel seems to label it.
Thanks,
Old 07-24-2011 | 12:43 PM
blue 20 amp under the hood the only one there
Old 08-17-2012 | 06:06 AM
SebringOwnerRJ's Avatar
Default Blue fuse did not solve mine
replace the blue fuse under the hood, neither power outlet working (one below dash and second in center counsel) Any other ideas please. Thanks
Old 08-17-2012 | 06:13 AM
Default Ligths in center counsel by shifter
On my center counsel there are small glass / plastic buttons representing the status of the gearbox shifter I.E. P, R, N, D, 3,1. Should these light up when I turn on my lights. And is so, are they part of the same fuse as the power outlets controlled by the blue fuse. Thanks
Cmike
04-08-2016 11:33 PM
makeamove
Cirrus & Breeze
06-09-2014 12:06 PM
baileyshbr
03-25-2011 09:35 AM
AZJOHN
06-30-2010 01:46 PM
dski76
08-03-2008 05:01 PM
