Where is the headlight horizontal adjuster?
I needed to adjust a new passenger side headlight housing. I found one adjuster, a T20 Torx screwdriver goes in vertically, it's to the rear of the housing and lines up with the right side of the A/C thingy. I turned it and it is the vertical adjuster. Fortunately that is the one that most needed adjustment.
But I could not find the horizontal adjuster anywhere. Could someone post a photo of it?
Thanks,
Buddy
Thanks,
Buddy
You are much more likely to get a helpful response if you let people know what kind of car you are asking about. Model (coupe or convertible/sedan) and year are essential when asking about a Sebring.
Anyway, there's a hole in the radiator support crossmember directly in front of the power steering reservoir. Look down in that hole. It should be there.
08, 2002, 2004, adjust, adjuster, adjusting, adjustment, chrysler, chyrsler, convertible, head, headlight, headlights, horizontal, light, sebring, tools
