2005 Chrysler 300...stupid question
Old 04-17-2008 | 01:53 PM
shawntmartin's Avatar
Default 2005 Chrysler 300...stupid question
I can't see the frame under the front end due to the plastic protection plate. Can someone tell me where I can place a floor jack so that I'm hitting the frame. I don't want to have toremove the plastic plate if I dont have to .
Old 04-17-2008 | 04:12 PM
moe's Avatar
moe
Default RE: 2005 Chrysler 300...stupid question
here you go bro.......
STANDARD PROCEDURE - HOISTING
1 - DRIVE ON LIFT
2 - SAE HOISTING SYMBOLS
2 - FRAME CONTACT LIFT (SINGLE POST)
2 - CHASSIS LIFT (DUAL LIFT)
2 - OUTBOARD LIFT (DUAL LIFT)
2 - FLOOR JACK
3 - HOISTING PADS
3 - FRAME CONTACT LIFT (SINGLE POST)
3 - CHASSIS LIFT (DUAL LIFT)
3 - OUTBOARD LIFT (DUAL LIFT)
3 - FLOOR JACK
The lifting points for the sedan.
Refer to Owner's Manual provided with vehicle for proper emergency jacking procedures.
WARNING: THE HOISTING AND JACK LIFTING POINTS PROVIDED ARE FOR A COMPLETE VEHICLE. WHEN THE ENGINE OR REAR SUSPENSION IS REMOVED FROM A VEHICLE, THE CENTER OF GRAVITY IS ALTERED MAKING SOME HOISTING CONDITIONS UNSTABLE. PROPERLY SUPPORT OR SECURE VEHICLE TO HOISTING DEVICE WHEN THESE CONDITIONS EXIST.
CAUTION: Do not position hoisting device on any suspension component, including the front or rear suspension crossmembers. Do not hoist on the front and rear bumpers, the lower liftgate crossmember, the lower radiator crossmember, or the front engine mount.
1 - DRIVE ON LIFT
2 - FLOOR JACK
3 - HOISTING PADS
3 - FLOOR JACK
The lifting points for the wagon.
Old 04-17-2008 | 08:00 PM
YOU ARE THE MAN!
Thanks!
kelcan72
12-20-2012 07:04 AM
kknobl
03-11-2010 07:12 AM
scfcarla
01-13-2009 09:21 AM
02-27-2006 10:54 AM
