300c drive train vibration
RE: 300c drive train vibration
ahh shux thanks for the boost of confidense
anyway what gear do you think its in i know they have a 3rd to 4th gear shudder with the nag1 trans
its got to do with water in the trans they do a complete flush and it should fix it if it is.
other than that i am going to start to inquire on this one.
HAY, I HAVE AN 05 300C IT TO HAD A VIBRATION, MINE WAS DO TO THE CROSS MEMBER UNDER THE CAR THAT WAS RESTING ON THE EXHUST SYSTEM. I HAD THE DEALERSHIP BEND IT DOWN AND IT WENT AWAY. THE 300C SETS LOWER THAN I THOUGHT AND THE BAR GOT BENT WITHOUT ME KNOWING IT, HAVE SOMEONE OR YOURSELF LOOK AT IT.
LATER
LATER
I had the same issue, dealer stated moisture was getting into the transmission via the fluid fill tube. Problem was corrected, shutter went away, but at 5800 the torque converter and pump failed. Not sure if related but the car has been down 15 days due to unavailable parts.
Print this out and show your service dept. Free of charge fix:
Reference Number: K72884665
Vehicle Issue: 1700 RPM vibration from exhaust system. Most likely noted at cruise speeds with light throttle application, when MDS (multiple cylinder displacement system) is activating.
Year: 2005
Model: LX - 300, LX - Magnum
Engine: 5.7L HEMI MDS only
System or Component: Group 11 - Exhaust
Symptom: Vibration. Verify that exhaust is mounted and isolated properly, correct as needed. IF all checks lead to no solution it is possible the following will assist:
Repair: A new flex joint has been released to break up the mode. In order to fix the car you will need 2 pipes and 2 spring/nut assemblies (Mopar calls it either a nut or spring, depending on the system. It's the same)
P/N 04581868AH (Muffler, exhaust. Qty - 1)
P/N 04581869AG (Resonator, exhaust. Qty - 1)
P/N 04578363AA (Nut, spring. Qty - 2)
Year: 2005
Zilla,
Thank you very much for this information! I am headed to my Chrysler dealer this morning to show them your information. This issue has bothered me for three years so I hope this resolves my problem.
Thanks again,
Moparman
Thanks again,
Moparman
spigot1
03-28-2014 04:36 PM
SpudlerT+CTouring
05-19-2011 06:02 AM
