Broke off Bolt on Sway Bar Bushing Clamp
1999 300m.
Was replacing sway bar bushings and broke off the head of one of the bolts for the bushing clamp. Any suggestions for removing it? It's a fairly tight space and the bolt appears to be harden steel.
Is an option to use a left-handed drill? I know there are other options. Just wanted to check on the best method before attempting this and potentially making it worse.
Thanks is advance for the advice!!
Thanks FIREM.
I drilled out the bolt from the bottom and re-tapped the threads. Couldn't find the same hardened bolt (10mx1.50x50) from any parts store including Chrysler (was told 90+ are backordered on the east coast. Went to a junk yard and took a couple from a wreck. Was able to put the sway bar bushing bracket back on with no problem!
Thanks again.
Thanks again.
99TandCMN
04-16-2018 06:25 PM
jgorczynski
06-08-2010 11:08 AM
3.3lxbluevan
01-30-2008 09:10 PM
