broken front power seat, need help.
Old 03-03-2012 | 03:56 PM
300c_cruser's Avatar
Default broken front power seat, need help.
i have a 06 300c. its got power seats and i moved the seat all the way forward and when it got there, the little shaft on the right of the motor broke, so now only one the outer side of the seat moves. does anybody know if there is a way to move the seat manually? it is stuck all the way forward so i cant even get to the mount bolts on the front? any ideas? anybody?
Old 03-09-2012 | 09:16 PM
chrysler300blk's Avatar
I have the Same problem
Old 09-10-2012 | 11:08 PM
sentrand's Avatar
mine will go forward and back. the front will go up and down. but the back will not go down. it was taken in to fix the plastic trim panel. when it went in the seat fully worked, the day after it went in i tried to put the seat down and it didnt move. the next week it went back in to be looked at. the service manager said it was tested and worked. i opened the door and tried to put the seat down. no go. hes just like well you can hearing the motor moving. that an expensive fix.
grifkac1
08-12-2015 02:35 PM
otrebmu
02-03-2015 04:24 PM
jd6158
06-06-2010 03:51 PM
Braves299
02-11-2009 01:23 AM
blue02
01-30-2006 11:36 PM
