No Wipers! Need Help Please!
Old 12-14-2014 | 11:32 PM
Christopher Kleiner's Avatar
Default No Wipers! Need Help Please!
Hi, I have a 2013 Chrysler 300 AWD. I currently have no windshield wipers. I checked the fuse and relay, both are working. The switch inside when turned on will "click" the relay. I checked and also have voltage at the wiper motor when the switch is turned on. The wire that shows voltage turns to ground when the switch is turned off. So I know I have the correct wire. Now here is where it gets weird. When I connect my OTC Encore scan-tool to the car it shows a wiper motor short. I don't remember the code off hand. Sorry. I really don't want to replace the wiper motor on a car with only 4K miles on it. Any help is greatly appreciated! Thanks
Old 12-14-2014 | 11:35 PM
Update on the car. It has a salvage title, was in a very bad front end accident. The so called "body guys" gave me the car back with all sorts of electrical problems. I've fixed almost everything but these wipers!!!
Old 12-15-2014 | 12:37 PM
The body codes i pulled from the bcm are, B2316-15 Wiper High/Low CtrlCir Short to Battery or Open and B2303-13 Wiper Park Switch InputCircuit Open. I dont have access to a wiring diagram or I'd be able to trace the wires. Can anyone please give me some info?
Old 12-15-2014 | 07:10 PM
Polarzak's Avatar
I would buy a wiper motor.
Old 12-17-2014 | 05:44 PM
I found a wiper wiring diagram, tested the motor by pulling out wiper relay #2 and jumping a wire from positive to the terminals for wiper output high and then for wiper output low. the motor works. wiper relay #1 is working correctly,when the switch is turned on the relay closes and sends power to relay #2. Im not getting a signal from the bcm to control wiper relay #2. I believe it to be a Brown/Light Green Wire. I have no clue where the BCM is located???? Does anyone know where to find it? I looked in the right kick panel and found a module but it does not look to be the body control module!
Old 12-17-2014 | 08:16 PM
the BCM is the instrument cluster in the 300s
Old 12-18-2014 | 04:27 PM
My cluster is not the bcm. I can unplug the cluster and everything else will remain working. I just tried.
Old 12-19-2014 | 02:15 PM
I stand corrected they moved the BCM from the cluster to behind tbe glove box in 2010
Contact
03-01-2013 08:56 AM
NdOfTyme69
08-21-2009 02:06 PM
wheels
03-24-2008 05:58 PM
webbch
01-04-2007 10:11 PM
SteveS2442
03-13-2006 12:08 AM
