P0513 code - flashing security light
Old 10-16-2018 | 03:51 PM
2005 300 LIMITED's Avatar
Default P0513 code - flashing security light
Hi,
When I got the car, I only got one original key.
I bought an unprogrammed key on eBay, had the key cut, and bought a SBB key programmer.
Figured I would program the key myself.
Well, the SBB key programmer was never able to program the key.
While I was tinkering around with SBB key programmer, I put the unprogrammed key in the ignition, started the car, and the engine shut down within seconds.
In researching the P0513 code, I recently read somewhere that if you try to start a car with an unprogrammed key you will get a P0513 code.
I bought a brand new Chrysler key, went to the dealer, and had the dealer program the eBay key and the new Chrysler key.
Now, when I use any one of my 3 keys (all 3 keys have new batteries and were programmed by the dealer) to start the car, the security light NEVER stops flashing the entire time the car is running and driving.
When I use the remote start (FlashLogic FLRSCH5 set up to use the factory key) to start the car, the security light flashes for a few seconds and then goes off.
When I put any of the 3 keys in the ignition after using the remote start, the security light stays off.
Did I create the P0513 code by when I started the car with unprogrammed eBay key?
I am at a loss!!!
Any help would be GREATLY appreciated.
Thank you,
George
zing77
07-01-2014 07:58 AM
thewheelman
12-12-2013 05:45 PM
james-jt
06-15-2012 09:16 AM
stevelist
05-29-2012 02:23 AM
sigep259
04-26-2011 11:55 PM
