P1005
P1005
Hi all I have a 2007 300 2.7 and I have a code p1005 I cleaned the valve and installed it code came back replaced the valve code came back, I’ve also seen some have had pcm issues so I replaced that code came back any ideas or anyone ran into this before?
I have a 3.5 so my questions might not make sense.
Did you ensure the mechanism is moving freely when you had the valve off?
Did you inspect the wiring carefully for breaks, cracks or chafing?
Did you check the pins in the plug looking for bent or loose pins?
Did you use good quality parts?
Did you try disconnecting the battery after installation to maybe clear the code?
Don't know if this will help, but these are the basic first things I would look at, hope it helps.
Did you activate the valve un-installed? If so, it worked ok? Did you attempt to turn the mechanism that the valve controls?
I guess the manifold could be gunked up, but not plugged, the car wouldn't' run.
If none of the things you have tried worked, my next step would be a known good shop.
I don't condone the "throwing parts" method of repair. But even more than that, I don't condone using AutoZone for anything. JMHO.
