07 Aspen SVC 4wd message
Old 07-17-2023 | 12:10 PM
Cadillacmat's Avatar
Originally Posted by edhunt0r
I have a 07 Aspen that has a problem with the 4wd engaging in lock mode intermittently and the SVC 4wd message coming on. Had it to the dealer and they could not duplicate it and said there were no codes stored. They drove it only about 6mi. After I left the Dealerhip it happenned again.
Checking to see if anyone else has had this issue.
I've read that you can take the 4x4 switch off when not in 4x4 and it will lock it into regular. It's either the transfer case motor or the wiring to the actual switch in the cab or the switch itself all the parts are fairly cheap and can be done at home!!! I haven't tried it yet but I'm starting to do it now wish me luck HAHA
Old 07-17-2023 | 09:07 PM
calamity coyote's Avatar
In most cases, it turns out to be the transfer case motor which is a bit of a pain to get to. You have to drop the cross member for the transmission as it sits right above it. The motor has a shield plate which you simply cannot remove with the cross member in place and it holds the motor in as well. Highly recommend not going aftermarket. I made that mistake. The plug apparently is a little too long and therefore I was not able to get the harness to seat in all the way. Got frustrated and just left it unplugged. It doesn't switch anymore, but I still have the "SVC AWD" light on my dash.
Old 07-17-2023 | 11:27 PM
Yeah I just got it in regular drive and unplugged the damn thing!! Good to go
Old 07-18-2023 | 09:09 PM
I tried unplugging the switch on mine when I first started having issues and it was still switching since it was the motor that was having issues. I had to unplug the motor to get it to stop switching. Glad you got it to stop with just the dash switch. Much easier to get to.
  #15
Old 07-18-2023 | 09:21 PM
No I disconnected the motor the switch didn't work...
  #16
Old 07-19-2023 | 09:25 PM
Gotcha.
15951a\
11-19-2009 08:42 PM
paulruffo
05-01-2009 05:49 AM
15951a\
03-16-2009 11:12 PM
dphickster
05-05-2008 10:00 PM
04-05-2006 09:31 AM
