08 Aspen dash brake light comes on
Old 04-09-2013 | 06:36 PM
Red_5's Avatar
Default 08 Aspen dash brake light comes on
The dash brake light on my 08 Aspen with Hemi and towing package comes on after driving for awhile. Pulling the brake release doesn't seem to do anything. The first time it happened, the brake fluid was low but still above minimum. I added fluid and the light went off. We drove it on some local trips without it turning on but it turned on again when my wife took it on a 6 hour trip to Mammoth. Brake fluid is still full. Pads all look good and I can't find any leaks at the calipers. I'd at least like to have an idea of the problem before taking it to a dealership. Thanks for any ideas.
Old 04-09-2013 | 06:56 PM
Djinn-n-Tonic's Avatar
All jokes aside.........
The plastic reservoir on the Master cylinder needs a SMACK.....
There is a magnetic reed switch at the bottom of the reservoir that gets gummed up and sticks . Hard cornering , bumpy roads, etc, will make the float bounce and momentarily contact the reed switch. if trhe switch doesnt release in a specified time interval, the CCN module will see this as a low fluid fault, and turn your light on.
Giving it a firm whack will dislodge any debris that may bind up the reed. If not, Replace the master cylinder.
Old 04-10-2013 | 08:49 AM
Red_5's Avatar
Thanks, I'll give that a try.
Old 04-17-2013 | 01:41 PM
Red_5's Avatar
The hammer idea didn't seem to work. I fully bled the system going through a large container of brake fluid - don't know if it has ever been bled before. The old fluid looked pretty bad so hopefully that was the culprit. So far I haven't been able to get the light to turn on but I haven't been on a long trip yet either.
Old 05-16-2013 | 12:36 PM
Red_5's Avatar
The light has been coming on but only after a 1/2 hour or so of driving. Goes off if you stop and start but then kicks on after another 1/2 hour.
So research is leading me toward an ABS sensor not functioning properly. Any thoughts?
Old 05-30-2013 | 12:33 AM
Jamel Barnes's Avatar
Default Me Too
Did you ever find the fix? Just took my Aspen to dealership today but they could not see any issue. They topped off the brake fluid and told me to bring it back if needed...well bore I got home the light came back on..
Old 05-30-2013 | 09:42 AM
Red_5's Avatar
No, still have the light. We don't drive the Aspen daily so it's not a priority. I think it has to do with the ABS sensors.
Did the dealership try to pull any codes? I was wondering if the brake system has trouble codes.
Old 10-16-2013 | 01:34 AM
Labam02's Avatar
Just bought 2008 Aspen Limted 4x4 used..and the brake light is doing the same as described above. Very intermittently. The BRAKE warning light comes on after a short time driving and stays on until turned off. When I turn it back on...no light. Owned this vehicle for one week and has done this 2x now. Taking into dealership in the am. Hopefully the issue can be diagnosed and resolved.
Old 10-16-2013 | 09:13 AM
Red_5's Avatar
Let me know what they have to say.
The brake light in our Aspen now only seems to come on when towing. I'm wondering if it's just an issue with the brake connector wiring.
Old 10-29-2013 | 10:57 AM
ChryslerCares's Avatar
Check the O-ring on the master cylinder and make sure it is not damaged. This can cause the light to turn on intermittently.
