2007 Aspen MyGig RHR upgrade, backup camera question?
Old 03-01-2013 | 11:01 PM
Sessholvlaru's Avatar
Default 2007 Aspen MyGig RHR upgrade, backup camera question?
I recently traded in my 2011 Challenger R/T for an extra clean brilliant black '07 Aspen for several "practical" reasons.
Now I have an RHR MyGig which needs to go into the Aspen, compliments of the Lockpick adapter.
I have sourced pretty much everything I need but the one thing I can't find an answer to is whether or not I can use the factory backup cam with the RHR/Lockpick.
My truck did not come with the OEM cam and for reasons of ****-retentiveness I don't want to install an aftermarket camera when an OEM bolt-in part exists.
Does anyone know if I can splice the OEM camera into a, AV harness to fit the Lockpick? It looks like the aftermarket camera has two wires and the OEM has three?
Old 07-11-2014 | 05:33 PM
Ponderosa340's Avatar
I'm hoping to upgrade to a MYGIG system. I also have a black 07 Aspen with UConnect, Nav and VES. Does anyone know which MYGIG system I should be looking for? It seems I will have to buy the LockPick adapter but after what it costs for the MYGIG system a few hundred more won't be too much of a stretch.
Old 04-26-2018 | 08:48 AM
Will Murray's Avatar
Default Epic waste of time
Why did you not just buy the newer model antenna? It’s $25-$30 on eBay used and takes all of 5 seconds to grind the tab so it’ll fit the hole of the older Chrysler vehicles. The connectors at the back of the vehicle are the same... that’s why I did with my 2008 Sebring hard top convertible when upgrading to the RHR...
Old 04-26-2018 | 08:50 AM
Why did you not just buy the newer model antenna? It’s $25-$30 on eBay used and takes all of 5 seconds to grind the tab so it’ll fit the hole of the older Chrysler vehicles. The connectors at the back of the vehicle are the same... that’s what I did with my 2008 Sebring hard top convertible when upgrading to the RHR...
Old 04-26-2018 | 08:51 AM
Default Remove double post.
sorry double post
Old 04-26-2018 | 08:52 AM
sorry double post
CharlieHigh
11-21-2017 07:21 PM
Ponderosa340
10-19-2014 01:24 PM
Sessholvlaru
03-21-2013 03:21 PM
str8hemi
04-05-2010 01:54 PM
chuckman
11-20-2008 10:13 PM
