2009 Aspen Hybrid radiator fan problem
Hi
My employer has asked me to look into a problem with his 2009 Aspen Hybrid. The radiator fan will not stop after the vehicle is shut off. it will keep running at full speed until the battery dies or is disconnected. Because there were so few built I am having a real hard time finding anyone with information. Does anybody here have any suggestions?
Fan wont turn off
Hi all, I am having the same issue with my 2009 Aspen Hybrid. It first started as a dead battery, then still occurs now after replacing the battery. I removed both relays titled rad fan low and rad fan high with no change, the fan remains running.
If anyone has managed to figure this out, would appreciate any guidance.
Many thanks
Many thanks
I took mine to chrysler
They said I need to replace the hybrid gateway module and the cooling fan - I don’t think the cooling fan has an issue because that is running right but it’s signal is coming from the gateway module (not a mechanic but)
so check this out —-> I have your solutions it’s two parts it’s the gateway module and the hybrid cooling fan BUT THEY DONT MAKE THE HYBRID COOLING FAN ANYMORE so what you can do which is what I’m doing is taking part 55361429AC and using the housing but replacing the fan inside of it with the fan of a bmw 600w fan motor so it will work
Dan400Man
12-04-2019 12:28 AM
Railroader85
11-29-2016 11:39 AM
