Aftermarket Exhaust
Aftermarket Exhaust
Has anyone installed an aftermarket exhaust on the aspen? If so did/are you having any problems with drone inside the cab. Also some companies are offering the magnaflow 15830 unit which is not correct, I was offered this unit and installed it. This is accually for the older durango, it had so much drone in the cab that I had to remove it. Now I see magnaflow offers the correct version as the 16779 unit. I am hesitant to purchase this and have the same problem. Anyone who done anything with there exhaust and has any input I would appreciate it.
RE: Aftermarket Exhaust
if you have the hemi with mds i dont think you can avoid the drone,i belong to the 300c forum, i think a lot of the members used the magnaflow they say has no drone. but that is something you will have to decide for yourself.
see one of my prior posts with pic.
I cut off the resonator (5.7L Hemi) and installed a twin tip stainless. Little to no noticable drone in the vehicle, but a very pleasant throaty acknowledgement when you step on it.
Less than $100 installed.
This Dynomax Kit includes a super turbo muffler. Now my Aspen has a magnaflow installed but its a bit to loud, espacially when hot or towing or driving up to hills. The drone at constant speed dont make it better.
Maybe would this dynomax kit be a bit quiter and maybe i try to install to this super turbo muffler a stock resonator at the end
to cut the drone.
No one has this dynomax kit tried?
to cut the drone.
