Chrysler aspen hid... Fog lights... 2007 aspen
Old 04-06-2010 | 09:51 PM
PEDROCCOTA's Avatar
Default Chrysler aspen hid... Fog lights... 2007 aspen
Hey how is everyone doing on here. Im new to this so im still trying to get the hang of it.
I have a 2007 chrysler aspen, i just did a hid upgrade on my headlights. It was easy and fast to install. Everything came out perfect. I installed 6000k lo beam bulbs. Which are awsome
i have another kit, h10 for my fog lights. The problem is i dont know how to remove the old one.
Do i have to remove the whole bumper?
Or just the light?
Anyone know how to do it?
Thanks!
Old 04-07-2010 | 12:47 PM
str8hemi's Avatar
BULB
CAUTION: Do not contaminate the bulb glass by touching it with your fingers or by allowing it to contact other oily surfaces. Shortened bulb life will result.
Disconnect and isolate the battery negative cable.
  1. Remove the fasteners that secure the front of the front fender wheel house liner to the bottom of the front fascia.
  2. Pull the front of the front fender liner rearward far enough to access the back of the front fascia.
  3. Reach under and behind the front fascia to access the front fog lamp housing on the back of the front fascia.
  4. Disconnect the wire harness connector (1) from the fog lamp bulb connector receptacle.
  5. Firmly grasp the bulb on the back of the housing and rotate it counterclockwise (2) about 30 degrees to unlock it.
Pull the bulb straight out from the keyed opening in the housing.
Old 04-07-2010 | 12:48 PM
str8hemi's Avatar
hope this helps post some pics up when you done
Old 04-07-2010 | 06:17 PM
PEDROCCOTA's Avatar
Thanks a lot...
After work im going home and giving it a try...
Pictures will be posted up... As soon as i get it done.
Thanks again.
Old 04-08-2010 | 11:22 AM
str8hemi's Avatar
no problem I still have my HID for headlights and fogs sitting in my garage just haven't had time, but i will one day and i'll also post pics
carid
07-21-2014 10:15 AM
ygtgxi
06-24-2010 04:26 AM
cognacaspen
06-10-2010 11:10 PM
sonic gihad
01-27-2009 09:29 AM
orance28
02-04-2008 08:41 PM
