Evap code?
Evap code?
First time post and have a question, I had the code read and was given P0456 code for evap emission small leak. what does this tell me that the gas cap is the problem or has anyone else had this same code and what fixed it?
You could have just answered the question that would have helped as not everyone is computer savy, your just being a wise ***.
I don't know the answer right offhand. I am not that computer savvy myself. I would have to do exactly what I mentioned to you to try. However, and I am not being a wise-***, thankyouverymuch, click on "search" which is in the black band very near the top of the page. In the blank box type in "P0456" and hit "go". You will see a list of threads where the term "P0456" is embedded in that particular thread. A little research of those threads MAY shed light on what you may need to know. I am not an expert, but before I ever ask a question I try to do a little research on my own to see if I can find the answer myself.
AND YOU DIDNT ANSWER HIS QUESTION EITHER......
456 is a Small evap leak...... A gascap, a Pinhole in a Hose, A leaking purge solenoid...You name it.... anything that will allow vapor to escape the sealed system....
