Fuel Saver Mode???
Old 02-29-2012 | 09:39 AM
Triple Black 88's Avatar
Thanks guys, good to know. I have never seen it on my '07 and was starting to think something was wrong.
Old 03-08-2012 | 07:58 PM
Brotha J's Avatar
Originally Posted by conversion02
...despite getting approximately 18 mpg hwy. There's no way I'd be getting 18mpg hwy if it wasn't in msd/dod mode...
What's this msd/dod mode?
Old 03-09-2012 | 03:19 PM
15951a\'s Avatar
It shuts down 4 counterbalanced cylinders and runs on the other 4 when it can (adequate power, etc.).
Old 03-12-2012 | 01:40 PM
tinman's Avatar
This is all in the name of fuel economy. It works great on the Interstate with cruise control, etc.
  #15
Old 03-13-2012 | 08:19 PM
Thegut's Avatar
I just purchased a 2009 Aspen about 3 weeks ago. I have yet seen the fuel saver displayed. Should it be displayed in the main cluster or in the overhead EVIC where the temp and other features display?
  #16
Old 03-14-2012 | 06:51 PM
15951a\'s Avatar
It will display when engaged on the MPG display within the EVIC. Once you see when it kicks on/off, you'll be able to feel the engine transition back and forth between 4 and 8 cylinders. It's very subtle, but noticeable if you know what you're looking for.
  #17
Old 03-16-2012 | 09:04 PM
Thegut's Avatar
I have driven the vehicle at different speeds on the highway with cruise on. I still have not seen the "fuel saver" displayed. Nor have I felt any transition in the engine. Should I have the MDS checked or is there a flash for the computer? According to the MPG display I am only averaging 15 MPG. Would greatly like to see 18 mpg or better. Any suggestions?
  #18
Old 04-18-2012 | 09:38 AM
ruhroh's Avatar
I'll bet the hitch installer damaged the wiring causing a fault as no others have seen the same message.
  #19
Old 11-21-2020 | 02:44 AM
Tammy George's Avatar
Default "fuel saver mode"
I'm pretty sure that the fuel saver mode in the com panel up top does not display fuel saver mode on an 07. I believe that was something that they decided they might actually care to show you on 08-09 models. I have an 07 and have never seen it, despite getting approximately 18 mpg hwy. There's no way I'd be getting 18mpg hwy if it wasn't in msd/dod mode.
Double check the manual.
07 shows on dash only when the settings shows the mpg
conversion02
10-27-2010 10:47 AM
96BTC
09-27-2010 10:29 PM
jcl_cls01
08-03-2009 04:05 PM
09aspen
07-29-2009 05:05 PM
RayDog26
10-20-2008 02:18 PM
Quick Reply: Fuel Saver Mode???
