Heating System
Heating System
My 2007 Aspen's heating system seems to be screwed up. When we get into the car and start it up, the front heat controls all both on "low". We turn the heat up to 70 degrees and the interior heats up nicely. The next time we start the car, the controls have reverted back to "low" again. We have to set the heat controlls for both sides evertime we get into the car whether we used "manual" or automatic" settings.. This make no sense and it makes the remote start useless to warm up the car or defrost the windows..
I had it in to the dealers who doesn't know what is wrong and can't fix it and is not even sure if anything is wrong. Chrsyler customer service looked into it and doesn't know how to fix it if it is not operating properly and the don't know if it is operating correctly or not.
Has anyone else had this problem? How does your system work?
RE: Heating System
Do you have the Automatic heating and cooling system? The Temp is part of your memory selections.
When you unlock the car with the remote, the radio, seat, A/C system, mirrors, are all reset to the keys' memory settings. To reset, adjust the temp settings to where you want them, pust the memory center button and then the driver number to save everything. Make sure the seat and mirror settings are where you want them before doing the reset.
Should solve the problem.
RE: Heating System
Thank you very much for your reply and I will try your suggestion. The only problem with the "memory" method of setting the heater controls is that every time I want to change the "default" temperature when I start the car I must reprogram the memory. That just doesn't sound right. I live in the Northeast and may run the heater to 75 degrees when it is 10 degrees outside. The next day it may warm up to 50 degrees and I don't want the heater to always start at 75 degrees....what do I do...reprogram the memory? What I want is to have the heater/cooler operate at the temperature setting and fan operation I last had it on when I turned off the car. Can that be done?
ORIGINAL: jimhild
RE: Heating System
ORIGINAL: Watcher
ORIGINAL: jimhild
RE: Heating System
ORIGINAL: jimhild
If you don't lock the car then it remembers the last setting when you next start the car. If you use the memory and lock the car then it reverts to your "standard" setting. I don't know of any way around this other than to reset the memory with a new setting before you lock the car for the night.
ORIGINAL: Watcher
ORIGINAL: jimhild
I guess you are telling me that the settings SHOULD be remembered from start to to start if the gars is not unlocked using the remote key, and that is not happening.
RE: Heating System
ORIGINAL: Watcher
So far I don't have an answer to my question. When you turn off your Aspen with the heat temnperature set at ...say 72 degrees, is it still set at 72 degrees when you restart the car?
My memory position is 74 and that is the setting that will come up when I use my key fob. If I want the system to come on at 72 then I must reset the A/C settings and save that with the memory button or it will be set at 74 the next time I unlock the car. If I dont lock the car and come back to restart the car then the temp will be set at the last setting every time.
Hope this helps.
RE: Heating System
Thank you very much for your reply. My system is indeed not functioning properly. It never returns to the last setting no matter how I turn off or start the car. I am sure I can set the memory but I would be just want the heater-A/C be at the setting when turn off the car.
Again...thanks. I have something to tell the dealer who has no idea how the system works and neither does Chrysler Corp.
RE: Heating System
I had the same problem in the summer. I can not get the temp to come on with the AC with the remote starter. Chrysler told me that it sends air through the side and floor vents that is cool and on low but I don't have he option to set the AC temp. When using the remote start you can not get the Temp control until you put the key in. This holds true now in the cold weather. Remote start does not allow temp setup until key is inserted. However, it does remember my temp at 65 degrees when I insert the key.
