Loud clunk w/4wd lo
Old 09-22-2009 | 06:16 PM
15951a\'s Avatar
Default Loud clunk w/4wd lo
Hi everyone,
I engage the 4wd hi/low switches weekly just to make sure they're working correctly while I'm in warranty.
Question: When I change to 4wd high, it's a very smooth switch with just a small noise. However, when I change to and from 4wd low, there is usually a loud clunk - enough to where the truck vibrates a bit. Is this normal, or something I need to have checked out?
It seems to function just fine once I get it switched over, but it engages sort of violently.
Thanks!
Old 09-22-2009 | 07:11 PM
valleybill55@aol.com's Avatar
Default low axle
my aspen does the same thing,i also had a ford explore did the same way when i put it in low axle. i think this is normal bcause all 4 wheels lock at the same time. this a very low gear .
Old 09-26-2009 | 08:08 PM
15951a\'s Avatar
Thanks Bill - it's so loud that it sounds like something is getting broken down there, so I was a bit concerned. Glad to hear it's not unique to my vehicle.
Old 11-18-2009 | 12:38 AM
Al B's Avatar
I hope you guys are going into LOW with the vehicle stopped, and the tranny in N...
Old 11-18-2009 | 03:05 AM
wsimental's Avatar
Question LHS no start!!! HELP!!!
I have problem with my LHS 99 does not turn on and the battery is charged, does not make any sound not even the starter moves, can be any relay? and what may be?...
Old 11-18-2009 | 03:13 AM
wsimental's Avatar
Default 1999 LHS no start
Old 11-18-2009 | 06:55 AM
Default shift into low gear
you cant shift into low unless the vehicle is stopped. has to be in netrual with foot on the brake.before you shift in low gear.
Old 11-19-2009 | 08:40 PM
15951a\'s Avatar
Check out page 285 of your manual (assuming you have a 2008). The "preferred procedure" to change into either high or low is to shift into neutral from a slow roll (2-3 mph), select high/low, and shift back into gear after the position indicator light stops flashing.
I'm not sure why they prefer the vehicle to be moving. It works just fine doing it as you describe as well, which Chrysler refers to as the "alternate procedure".
Old 11-19-2009 | 08:42 PM
15951a\'s Avatar
If it clicks your starter probably needs to be replaced...if nothing, then I'm not sure.
By the way, you'll probably get a better response on this if you don't post it on a 4WD thread in a Chrysler Aspen forum.
BenjaminA
01-10-2012 05:14 PM
Puppeteer
08-06-2010 10:50 PM
paulruffo
05-01-2009 05:49 AM
15951a\
03-16-2009 11:12 PM
04-05-2006 09:31 AM
