Need advise from the Experts/Techs
Old 02-16-2011 | 06:58 PM
15951a\'s Avatar
Originally Posted by Djinn-n-Tonic
I know it goes off topic a bit, but since I see how this thread is going, I thought I should mention it....
I am NOT going to get into the debate over "Conventional" or "Synthetic" oils, because everytime I do it turns Ugly.....Unless the vehicle SPECIFICALLY REQUIRES it...Its your choice.
BUT...ANYTHING EQUIPPED WITH A HEMI, or anything equipped with Either MDS or VVT...REQUIRES THE USE OF 5w/20 Motor oil EXCLUSIVELY....
And in case you make a mistake, and use the wrong oil......He will be glad to tell you..
The oil control solenoids, and MDS solenoids are monitored by PCM for the amount of "BLEED DOWN TIME" in the respective system. Changing Viscosity, changes the bleed time, and PCM defaults the VVT and MDS systems, and sets a Check engine lamp. The DTC will read Improper viscosity lubricant.....
Who said they've decided the Hemi doesn't need 5w/20? That's all I ever use...
  #32
Old 02-16-2011 | 07:07 PM
Djinn-n-Tonic's Avatar
Because you were smart enough to look at the filler cap, or READ THE MANUAL....
You would not believe the arguments I have had, with customers, as well as other shop owners, over this...The vehicle JUST HAD the oil changed, and the Check engine light is on.
Of course in the customers mind, Its still under warranty, but when that IMPROPER VISCOSITY code shows up, It is not a warrantable concern, due to Improper svc procedures from another shop........
I will either change the oil again, using the proper grade, at the customers expense, or refer the customer back to the Lube shop, after paying the diagnostic shop fee...
AVR2
10-03-2012 03:56 AM
toofast4uu
01-19-2011 08:45 AM
Revolution
01-07-2011 03:20 PM
spjackso
02-21-2009 07:29 PM
motchai
05-11-2005 02:06 AM
Quick Reply: Need advise from the Experts/Techs
