Oil Change Intervals and Synthetic Oil
Hi all,
I use the 6k mile service interval, and have been using Mobil 1 for about 2 years now. Are any of you that are running synthetics going longer than 6k miles? That interval was the same regardless of conventional or synthetic, so every time I go to the shop and spend $90 on a 7-quart Hemi oil change I wonder if I'm pouring perfectly good oil down the drain.
Please let me know if anyone is going longer between oil changes with synthetic. I'm out of warranty, so that's not a concern at this point.
Thanks!
Thanks!
$90 is way too much. DIY. Most all auto parts stores run monthly specials of 5 qts synthetic + quality filter for $27-30. Add another 2 quarts, and you are around $40. Take 45 min of your time, and you are done. Oil changes on the Aspen are simple. If you are out of warranty, you can easily go 10K on most synthetics + quality filter. Check bobistheoilguy for more details.
I don't go 6 months, I go 6k miles. The point of this thread was to ask if anyone is doing extended service intervals beyond 6k miles with synthetic oil.
Are you using that same interval for your oil filter as well? Thanks for the response.
long oil change intervals
We changed the oil every 15K on my wifes bimmer with castrol full synthetic. It had 90K when we traded it on the Aspen and there where no engine issues. I change the oil every 7K on my Ford edge with synthetic blend, 70K & no engine issues. I am using Mobile1 in the Aspen on 7K intervals. 47K all is good. DIY synthetic oil change is less than jiffy lubes standard oil change on your Aspen. You don't evn need a jack to change the oil. My town will pick up 1 gallon of used oil on trash day.
