Park Assit Failure
Old 02-03-2010 | 06:53 PM
07aspen's Avatar
Default Park Assit Failure
I took my Aspen to the dealership because I keep getting a message in the evic when I start the vehicle "Service park assist system". They told me that 3 of the 4 modules had all gone bad. Suprised me that three went bad at the same time? Also they told me that it would cost me something like $260 bucks or around there to fix. No problem but when the thing did work it was so slow that I would have hit something before it would have warned me. Also I tow quite often in the sumer and therefor never use this option. Anyways is there any way to get the message from continuing to come up? The dealer says no, does anyone know different? Also these parts are easily removed if I replaced them myself would the problem cure itself or does the computer need to be reset also?
Old 02-06-2010 | 11:15 PM
15951a\'s Avatar
There are 4 distance sensors on your back bumper that work with the system, but only one control module that I know of. The control module is located behind the power liftgate module above the left rear wheel housing.
Did you ever back into anything? I can't imagine how 3 of the 4 sensors would just go bad.
You have to remove the rear bumper cover to remove/replace the sensors. I'm not sure about clearing the code without repairing the problem.
kc9dre
07-11-2008 11:26 PM
adsebring
06-20-2008 09:25 AM
kunzite
12-11-2007 04:13 PM
pconner98
08-22-2007 12:12 AM
ctlo003
07-13-2007 06:24 PM
