Power side mirrors not working
I'm going to assume you mean that the side mirrors cannot be adjusted with the switch, but that they still tilt down in reverse per your settings. I'm also going to assume you have toggled the switch between left and right for testing, and you are not simply moving the "joystick" with the switch in the middle (off) position.
If the above is true, you probably have a bad mirror switch, which will require replacement as follows:
1. Disconnect the negative battery cable.
2. Pry the wood trim to remove the entire switch assembly with windows/mirror/lock switches.
3. Disconnect the electrical harness from the back of the assembly.
4. Remove the power window switch from the assembly.
Install is the reverse of the above. Of course, you'll need to order the part online or from your friendly neighborhood Chrysler dealer.
Good luck!
Good luck!
doctorgee
07-15-2024 09:42 AM
Spenosa
02-28-2013 04:42 PM
Bev25
11-18-2006 07:24 PM
