Rebuilt engine will not start
Old 06-28-2014 | 08:03 PM
drake1's Avatar
Default Rebuilt engine will not start
I have a 2007 Chrysler Aspen with a 5.7L. I just purchased a rebuilt motor because the last one ran hot. I have placed the new motor and everything is hooked up but will not crank. It will turn over all day long and want to crank but will not. I am all out of ideas on what could be preventing this. Any help is appreciated.
Old 06-28-2014 | 10:41 PM
same year engine as u took out? Professional rebuilt? what about the cam and crank sensors are the working?
Old 06-29-2014 | 07:22 AM
drake1's Avatar
It is the same year and it came from Spartan engines. The only codes that are popping up are the IAT Sensor 1 code when we plugged up the machine we borrowed from Advance Auto.
Old 06-29-2014 | 02:18 PM
15951a\'s Avatar
If you're smart enough to install a rebuilt engine, you already checked the obvious stuff we're going to mention -- new plugs, check fuel pressure, make sure injectors are good, etc.
Old 06-29-2014 | 04:38 PM
drake1's Avatar
Got the car started. Was ceank sensor but now its running hot. Thermostat is working. Any ideas?
Old 06-29-2014 | 09:27 PM
fan working?
Old 06-30-2014 | 02:33 PM
15951a\'s Avatar
Fan, thermostat, radiator, and water pump. If it's any of these things and you replaced the engine only because it ran hot...
avondj40
05-17-2015 12:38 PM
hink-aspen-07
10-24-2012 11:17 PM
jeremiahm
03-06-2012 06:23 PM
Attitude0917
06-15-2008 12:15 PM
E85Fan
03-20-2006 03:45 PM
