Trailer running lights
My trailer running lights don't work. Flashers, brakes, and turn signals work, but the running lights are out. I checked the output to make sure nothing was wrong with the trailer and there's no output from the vehicle at the trailer harness.
Sounds like a fuse, but why (and WHERE?) would Chrysler wire up running lights on the tow package independently from the others (flashers and brakes)? I saw a fuse in the box for the tow lights, but that was it. Is there a separate fuse (10A?) for the trailer running lights???
Thanks!
Thanks!
I'm having thus exact same problem. I switched out the relays and a 20A fuse for tgthe tow package but still no running lights.
It would be nice to know where this 10A fuse is 😁
Multiple fuses under the hood with two boxes.
Power Distribution Center is the box closest to windshield.
Cavity 23 - 20 Amp Yellow - Trailer Tow
Integrated Power Module, second box from windshield.
Cavity 5 - Relay - Lt Trailer-Tow Stop/Turn Relay
Cavity 6 - Relay - Rt Trailer-Tow Stop/Turn Relay
Cavity 9 - 10 Amp Red - Trailer Tow Park Lamps
So looks like you are looking for a red 10 amp fuse in the second box under the hood. It will be the one closes to front of vehicle on the right when you raise the hood.
I replaced the two relays with what was already there (pic attached). I used the numbers on top to find a replacement.
Tommy Harrell
11-08-2013 08:19 AM
