Crossfire headlamp bulb replacement
FYI…I just replaced the bulb in my passenger head lamp. Thought I would share how[/i] to[/i] for my fellow Crossfire owners. Be warned! It is not the easiest bulb to replace.From the engine compartment, remove the rubber boot that covers the affected light. Work yourself to where you can see in the light well (not as in see it good). The well is where the light is. Using a trouble light and a mirror will help. The lamp is held in by a wire clip. Study the clip.It is hinged and you can squeeze the clip and it comes free.Try not remove it from the hinge!!! It just holds the lamp in place. Terrible design! The lamp comes out and you can replace it with an $18 dollar lamp. On install put the lamp in alone first and then re-secure the clip over the lamp and then plug the socket back into the lamp itself...otherwise the wires will be in the way. The clip is designed to hold just the lamp.It's apain and probably worth whatever they would charge to replace it, but it can be done.
Johnny K
01-21-2010 08:09 AM
vartech
03-09-2009 10:34 AM
2004, assembly, bulb, bulbs, change, chrysler, clip, crosfire, crossfire, headlamp, headlight, installing, repalcement, replacment, wire
