04 pacifica misfiring p301,p302
Old 04-01-2010 | 08:45 PM
epac's Avatar
Default 04 pacifica misfiring p301,p302
2004 pacifica continiously misfiring diagnostic shows cylinder 2 misfiring I replaced the spark plugs didnt work replaced the coil didnt work and finally replaced injector but still cylinder 2 misfiring anybody please tell me what else to try diagnostic shows 301 and 302 and I beleive cylinder 2 is the middle one from the front row under the intake
Old 04-01-2010 | 11:54 PM
Virglijus's Avatar
All possible causes:
INTERMITTENT MISFIRE
VISUAL AND PHYSICAL INSPECTION
IGNITION WIRE
ASD RELAY OUPUT CIRCUIT (COIL)
ENGINE MECHANICAL PROBLEM
IGNITION COIL
COIL CONTROL CIRCUIT
SPARK PLUG
CHECKING FUEL PRESSURE
FUEL PUMP INLET STRAINER PLUGGED
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP MODULE
CHECKING FUEL LEAK DOWN
FUEL INJECTOR OPERATION
ASD RELAY OUTPUT CIRCUIT (INJECTOR)
FUEL INJECTOR
INJECTOR CONTROL CIRCUIT
PCM (IGNITION SYSTEM)
Old 04-02-2010 | 02:27 AM
mrfixit454's Avatar
isn't 301 and 302 a #1 and #2 misfire?
Old 04-02-2010 | 03:59 AM
Virglijus's Avatar
Yes, it is. The cylinders are numbered from front to rear, with the right bank odd numbered, and the left bank even numbered.
RCSnyder
05-24-2014 10:12 PM
ronypal
03-29-2012 07:20 PM
LemonSebring98
07-04-2011 12:15 PM
ddalbyr
05-12-2011 10:19 AM
ChryslerNamedTrixie
09-20-2005 05:57 AM
