04 Pacifica Oilpan
Here are some options:
1) New Oilpan= lotsa bolts, gasket removal, gasket replacement. $ parts+labor
2) oversized self-tapping plug is a tapered plug, but are prone to leaking if the original hole was badly stripped. Very easy to do, just make sure you do not over-torque!
3) helicoil works well if you re-tap it straight so the plug seats properly. Maybe practice tapping holes before you try this for the first time.
4) re-tap the hole and use a bigger plug. Also easy to do with a bit of practice
