04 pacifica tranny problem! Help!
Old 07-26-2007 | 03:46 PM
04_pacifica_4u's Avatar
Default 04 pacifica tranny problem! Help!
I think my 04 pacifica tranny is done. When it is put into Drive or reverse it doesn't move but when it is in park it makes a grinding noise. Any help on this would be great. It was making a popping noise when I made sharp corners about a week ago and now this. Let me know. Thanks
Old 10-22-2008 | 04:28 AM
goodwin1's Avatar
Default RE: 04 pacifica tranny problem! Help!
I presume you have checked the tranny fluid. The noise you were getting can be an indication that the torque converter is low in oil or rather the tranny is low in oil and as you turn the corners the oil is slushing about and not engaging the torque converter properly.
Old 10-22-2008 | 10:43 PM
dodgetech1's Avatar
I bet your center differentail blewed up. need new.
Old 02-20-2009 | 02:21 PM
It was the front turbine speed sensor. Cost like $15 at autozone.
Old 02-20-2009 | 08:58 PM
moe's Avatar
moe
That can,t be it!Did the sensor have metal on it when you pulled it out?
silenthunter
05-06-2016 07:29 PM
ttype
04-26-2014 06:43 PM
undead
06-18-2009 10:59 PM
Adamo
06-20-2007 09:42 PM
ajsproaudio
Cirrus & Breeze
01-24-2006 12:13 PM
