05 Pacifica Blower motor question
Old 06-25-2010 | 02:51 PM
gooch's Avatar
Default 05 Pacifica Blower motor question
Blower motor not working. Replaced the motor and nothing. Green wire +12.28v and black wire +12.28v while on. Its the auto system. Blower doesn't come on at all, everything else is fine. I've read that if its the module usualy it stays on high. Should I replace it anyway?
Old 08-03-2010 | 08:40 PM
cmmiller22's Avatar
Did you figure this out? Exact same problem on my '04. ATC system, so I replaced power mdule/resistor and have same exact problem.
Old 08-12-2010 | 01:53 AM
minvi's Avatar
This happened to me recently and I simply replaced the blower resistor module and it worked fine.
Have you tried simply connecting the power and ground (coming out of the resistor module) to see if the fan is operable?
Old 08-12-2010 | 01:56 AM
minvi's Avatar
I meant to the fan, of course.
Old 05-28-2011 | 04:39 PM
karfreek's Avatar
Ok, I had the same problem as the original poster. Mine turned out to the the resistor control module. It was $86 for a new one at Advance Auto and they had it instock. The replacement has 5 prongs not 6 like the original, but it works as there is only 5 wires going into the harnesses.
The diagnosis was tricky as I was getting 12.5v at the motor but it was not turning. When the motor was connected to a 12v source it worked. I tried the module with help from a sympathetic parts store manager and it worked, so I bought it. Hope this helps someone.
I have ATC, the module is behind the glove box with two screws holding it in place, two harnesses coming out, one going to the blower.
Jay
Gravity1982
05-31-2015 10:06 AM
ebby69k
07-09-2013 09:31 AM
RonVF
08-04-2011 06:33 PM
bmfay
04-09-2007 09:37 PM
bmfay
04-02-2007 10:49 PM
