05 pacifica no horn
Old 02-14-2019 | 03:52 PM
Mr.got's Avatar
Default 05 pacifica no horn
I thought it would be the clockspring, but everything else on steering wheel works. Only non function is the horn, any ideas
Old 02-14-2019 | 04:19 PM
REBEL59's Avatar
At least you were thinking...But what have you checked/tested? How long has the horn not worked? Fuse, relay horns themselves??????
Old 02-14-2019 | 04:30 PM
Mr.got's Avatar
This has been an issue for awhile (6+ months). I have not checked fuses or relays yet. Can't find fuse box or diagram of fuses to know which one.
Old 02-18-2019 | 09:23 PM
Mr.got's Avatar
so I've checked fuse and relays and those are good. How to check horn itself or even clockspring, if everything else on steering wheel is working?
Old 02-19-2019 | 12:33 AM
BiliTheAxe's Avatar
Testing the horn is easy.
1st: locate the horn.
2nd: disconnect wire/s from horn.
3rd: connect the horn directly to 12 volt source.
4th: if the horn scares the crap out of you when it makes noise, change pants.
5th: Connect volt meter to wire/s that were connected to the horn, and have someone try to sound the horn, look for signs of voltage reaching the horn.
Old 02-27-2019 | 12:03 PM
srp365's Avatar
I had an issue similar to this. Bad ground is what it turned out to be, search google for South Main Auto Pacifica and you'll see an issue Eric O tracked down to a bad ground under the battery.
Another electrical gremlin I had I traced back to a PAC Steering Wheel Control Interface for my Pioneer. Caused all sorts of grief.
flynavyj
9
03-29-2023 05:20 PM
Bassturd
09-21-2019 08:26 AM
Tim King
Cirrus & Breeze
10-31-2014 12:37 AM
JohnnyD06
06-20-2014 03:53 PM
sidhabo
08-21-2009 01:53 PM
