06 Pacifica ABS light
Old 03-08-2009 | 09:37 PM
pearly28's Avatar
Default 06 Pacifica ABS light
I have a 06 pacifica and the ABS light is comming on. Every so often the brakes chatter and catch. I took it in and they said I needed a new left rear wheel bearing for $500. Does this sound right? Thanks in advance, Joyce
Old 03-08-2009 | 09:58 PM
nope u need wheel speed sensors not a wheel bearing and I would replace all of the sensors they have a bad habit of failing one after another the dealer has a TSB on this issue don't take it back to the people that told U that U need a wheel bearing.
Old 03-23-2009 | 06:50 AM
Thew1096's Avatar
Is the sensor connected to the bearing or is this something you can do in your garage? Everyone keeps telling me that the sensors are built into the bearing and both will need to be replaced. Is this true?
Old 03-23-2009 | 03:19 PM
not true the chrysler sensors are the sensors only U haft to take loose the hubs not replace them.
Old 03-24-2009 | 12:14 AM
Pacifica3.82007's Avatar
Are all model year Pacifica's affected by this? Something else fantastic to look forward to.
Old 03-24-2009 | 07:29 AM
Old 03-24-2009 | 08:55 AM
At last, something on my vehicle not covered by a tsb...
Old 03-25-2009 | 01:04 AM
if anything U want to have a tsb with that U know what the issue us and what it will take to fix it.
Old 03-25-2009 | 01:35 AM
chterryiv's Avatar
I had to have this replaced on right and left side of my 05' pacifica. Luckily i purchased extended warranty.
Old 03-25-2009 | 04:23 PM
True...
