06 Pacifica Burning Oil
Old 07-14-2008 | 09:49 AM
snpmich's Avatar
Default RE: 06 Pacifica Burning Oil
i own a 2005 pacifica and absolutely love it....except it does burn oil....don't get smoke...engine noise...or any droppings on the garage floor....i just know about ever 1k to 2k miles....i have to add a quart of oil....luckily the oil changing place i go to will add up to 3 quarts of oil every 3k for no charge....
Old 09-24-2008 | 03:03 PM
STIGuy's Avatar
Got an '04 Pac of my own with 106k miles now (bought used with 98k miles 12 months ago). Was going through about 1qt of oil every 1000 miles.
On the drivers side of the engine (oposite of the belt)are two metal "triangular" plates (front and back), about 3" across and held in place with 3 bolts,that cover holes in the engine block where the cam shafts ride. I replaced these plates (Chrysler has a new design from the OEM design). This helped a LOT. I now burna little less than1qt every 3k to 3.5k. I also replaced the valve cover seals at the same time but I don't think this did anything.
The cam shafts are on the upper half of the engine so I think the oil was leaking around the seals of these plates and getting burned off before ever landing on my garage floor. New plates and seals was about $20 and about 1/2 days effort to tear down and back up again.
HarleyRob
08-11-2015 03:12 PM
excitingleopard
05-18-2011 03:26 PM
dhhbomb
04-16-2009 11:32 AM
RayDog26
02-15-2009 10:29 PM
rollingrock
01-07-2009 01:50 PM
