06 Pacifica trailer taillights inop
Old 07-24-2008 | 12:36 AM
SGTSCHU's Avatar
Default 06 Pacifica trailer taillights inop
Hey guys n gals,
Just hitched my 06 AWD and transferred oem trailer wiring from my 04 to this 06. Everything plugs in the same but I have no taillights. I cant plug it back into my 04 since it is gone already but I am sure it worked a few weeks ago when I last pulled my boat. Am I missing something? They didnt change the harness from what I can tell??
Old 07-24-2008 | 10:57 AM
SARG's Avatar
Default RE: 06 Pacifica trailer taillights inop
Suggest you get a test light and probe the connectors on the car to isolate where the problem is located.......... in your wiring connections ...or now in the trailer side.
Old 07-24-2008 | 11:06 AM
SARG's Avatar
If it's a simple four plug cennector ...... the green wire is the passenger side stop/turn..... the yellow is the driver side stop/turn and the brown is the power to the running lights.
Old 07-24-2008 | 11:27 AM
SGTSCHU's Avatar
Yes, just a simple flat 4, seemed to be simple enough. Plug ang play right? I have power going into harness and back out to taillight on left rear. Harness pulls tail and left turn from left taillight harness and right turn/stop from right taillight circuit. All works on vehicle and all except taillights at flat 4. I was told there was no difference between 04 and 06. If this is correct, I must have a bad harness then....no matter how big the coincidence.
Old 07-24-2008 | 11:46 AM
SARG's Avatar
Simple test light will isolate where the problem is located.
Old 07-24-2008 | 11:49 AM
SGTSCHU's Avatar
sure....
Toby32
02-28-2015 02:10 PM
trf012
Other
08-05-2011 08:00 AM
bjorn4711
05-26-2009 02:25 AM
cognacaspen
07-24-2008 09:33 PM
josh81
12-17-2007 07:27 PM
