2004 Chrysler Pacifica no heat
Old 12-15-2013 | 12:39 PM
u1701's Avatar
Default 2004 Chrysler Pacifica no heat
2004 Chrysler pacifica with no heat. I have checked the antifreeze and it is fine. Blower works but just blows cold air. I see two hoses going into the dash from the engine compartment and they are warm, not hot, but just warm. I also noticed when I press the recirculate button it just flashes three times and goes off. any guidance would be appreciated
Old 12-16-2013 | 12:56 AM
how are you checking the coolant? With the ones the over flow tank and fill cap are built into one assembly the coolant will need to be at eh vary vary top this will ensure u have the right amount in there check it on a flat level area.
Old 12-23-2013 | 05:43 PM
Zillah's Avatar
You may have a bad blower motor relay. That happened to mine. It's an easy fix because it can be accessed through the glove compartment. The part cost me about $90 and took literally 10 minutes to install.
Old 12-23-2013 | 09:54 PM
ahhh no read carefully what he says "Blower works but just blows cold air"
Old 12-27-2017 | 09:07 PM
Kevin Matney's Avatar
I have a 2007 with a 4.0 and it has the same thing that just started at 110k. No heat at all,just cold *** air
Old 12-29-2017 | 01:55 AM
read the above what I asked him to look at then get back on here
Old 12-29-2017 | 08:51 AM
I keep getting a smell of coolant every so often, put in a 1/4 bottle of leak stuff of the heater core. for aluminum rads,.I still get a small smell of it not as much. the blower is fine.have not lost any coolant.
Old 12-29-2017 | 09:14 AM
REBEL59's Avatar
In anything but DIRE emergency would I use that type product...and then ONLY for a very temporary fix! If you are smelling coolant inside the car there are 2 possibilities.
A Loose clamp for a heater hose from motor to firewall(leading coolant spray into HVAC box)
OR a leaking(bad) heater core.
As far as not loosing coolant, the reservoir may be full but what about the radiator and the motor(air entrapment)? AND have you ever had the thermostat replaced?
Old 12-31-2017 | 10:39 PM
I do not have a drain in my shop to flush it out. I will try a shop vac to catch the water from the flush out then letting it go to the floor.
Old 05-04-2018 | 01:03 AM
It dose not over heat,and 1 of the tulbs is warm and the other is cold. In the winter. Now it is warm I lost my AC too. All I get now is hot air no madder what I do
