2004 pacifica control arm bushing
I am trying to find out if there is a control arm bushing availiable for the 2004 pacifica without having to buy the whole control arm. I have a clunking noise when I hit bumps and mechanic says bushings are bad but told by chrysler dealer that you can only get them if the whole control arm is replaced. Seems a little much to have to buy a $200 part to get bushings replaced. Any info would help on this.
I show them available. Check Here. By the way, that site shows list on the full control arms at over $400.
I bought the whole arm with bushings and ball joint from Rockauto because the bushings were bad on ours and we had a clunk over bumps. It did not fix it. What did fix it was $16 sway bar bushings. The did not look bad, but when compared to the new ones they were egg shaped, hardedned and cracked. Try that first if you can. No alignment needed, either.
Jay
Jay
You can order the bushings from Germany
2X QUERLENKERBUCHSE VA/HINTEN CHRYSLER PACIFICA ab 2003 | eBay
or
maparts.de
These are the big control arm bushings, the small bushings fit from Caravan/Town and Country till 2007 model year mopar part number 4684120
or
maparts.de
Lanatwo
12-30-2013 08:33 PM
