2005 Chrysler Pacifica - RPM going up and down by itself - sometimes stops running
Old 07-27-2015 | 03:07 PM
jimmy154's Avatar
Default 2005 Chrysler Pacifica - RPM going up and down by itself - sometimes stops running
I keep the pedal constant, but RPM goes up and down.
Alternator is 1 VDC to low at 13.45 VDC, but it has been like that for some time.
Stops running sometimes too.
Smells like gas out of the tailpipe when the revs flucate, so I think it's getting fuel when the revs are falling, but gas is not igniting, but I could be wrong about what the smell is.
Here is a video of it happening:
Old 07-27-2015 | 06:04 PM
jimmy154's Avatar
Problems only occur roughly at idle, when you try to go.
And then when in park the idle fluctuates.
I can't drive it and it goes past 3,000 RPM
But when in part the RPM just bounces from 2,000-2,500 RPM (now it's a little lower, the last time I tried it) by itself.
Old 07-27-2015 | 08:16 PM
xfire04's Avatar
sounds like a tps
Old 07-28-2015 | 12:42 AM
MR jimmy this is modern electronics and computer systems programmed to do certain things with certain guidelines. Like take for-instance when you in park a software guy figured there is no reason for you to rev the engine over say 3k rpm when your not going ne where. so what they did is program the PCM when in park revving the engine over 3 k they shut the fuel off because well what the hell do you need to rev the engine up for? it not a hot rod your not gonna peal out in a family car are ya? nope. What are are experiencing is normal .
Old 07-28-2015 | 08:46 AM
jimmy154's Avatar
Interesting
It was bouncing at roughly 400-500 rpm higher not long ago
Also it smells when it does this
Same smell I smell when it wants to stall out at low speed or stalls out at low speed
Old 07-28-2015 | 02:29 PM
it smells like that because the computer is shutting the fuel on and off while your holding the throttle open.
Old 07-29-2015 | 07:07 AM
jimmy154's Avatar
Okay, thanks for the help.
Could it be possible my problems are caused by a weak alternator?
I only get 13.45 VDC.
My main problem is the car "shuttering" or not running well at low RPM and going from a stand still.
And shutting off at low speed/RPM, 0-15 MPH or so.
Old 07-29-2015 | 12:50 PM
the alternator is putting out the correct amount of volts for the currant situation. Turn on you head lits and blower motor the volts will go up.
Old 04-14-2016 | 02:02 PM
Rich DiSanto's Avatar
Default Normal?
How can that be normal? I have the same issue..2004 Pacifica..car goes to 4000 rpm on start up then bounces between 2-3 rpm car shifts fine but I have no brakes and when you press the gas theres nothing! Car does not move or brake!
Old 04-15-2016 | 08:41 AM
his issues was doing it when this happens
sounds like yous is when your driving. so you have a vac leak
