2005 Pacifica Satellite radio static hiss
Recently, our 2005 Pacifica has developed an intermittent hiss on Satellite Radio ONLY.
The FM, AM, Cd etc, all are fine.
I have read the threads about the antenna upgrade, I tried to troubleshoot it this way.
With the radio on, and making the hiss, I unplugged the connector for the antenna on the passenger rear window.
The reception did not change at all, just the same reception AND the same hiss.
Then I switched it to FM and did the same, the signal cut out altogether.
Any ideas?
Any ideas?
Got it thanks...
I have found that there is a TSB for this problem, basically the Satellite module is no good.
I will post the full story as I get all the details, but it is definately my problem.
If you have noise over the Satellite ONLY and you can still hear the radio in the background behind the hiss, not like a coverage problem, stay tuned.. ha.. and I will report shortly.
