2005 Pacifica Wheel shake
Have a slight steering wheel shake...thought it was rotors/brakes. Replace both, actually all 4, still there.
Jacked up the car again, if I hold the driver side tire and 9 and 3, and try shaking the wheel, it moves a slight bit. If I hold at 12 and 6, does not move.
Tried the same with the passenger side, does not move at all for either.
Guessing this is the problem, but what is the issue? Ball joint? Bearing?
Thanks in advance.
Thanks in advance.
I agree with the previous poster. 9 and 3 is typically tie rod end. Outer more so than inner in my experience. Hold onto the tie rod end where it meets the knuckle while you or someone else moves it and you can usually feel it.
It's an easy fix. You'll need something to separate the ball joint stud, either a pickle fork or a puller. Many parts stores will rent or loan the tool. Count the turns when you thread off the end from the tie-rod so you can thread on the new onethe same number of turns and preserve your toe-in adjustment. Or pay for a wheel alignment afterwards. Probably the best plan.
If you wait until it fails completely you can lose steering. Not a good development.
97K15004WD
08-26-2007 08:35 PM
